8L Knowledge Base
Assemble the Machine Stand
Tools and Items Required
  • 19 mm socket wrench
  • Cardboard piece, large
  • Phillips screwdriver
  • Work gloves
  2. Remove the screws from the bottom of the crate with a Phillips screwdriver.
  1. Before you lift the top of the shipping crate off of the pallet, verify that you have assistance to help you. We recommend lifting it with at least two people.
  2. Remove the top of the shipping crate and set it aside.
  3. Remove the plastic wrap from the machine stand.
  4. Inspect the item(s):
  1. Remove the coolant tank from the right-hand cabinet of the machine stand, and set it aside.
  2. The door for the right-hand cabinet is shipped inside the left-hand cabinet. Remove the plastic wrap from the door and install into the right-hand cabinet opening.
  3. Find the accessory box inside the machine's stand, which includes the legs for the machine's feet assembly. Set it aside for later installation.
  4. Find the tool box inside the machine's enclosure, which includes the machine's feet, the Ethernet cable, and four M10 lifting eyelets. Remove the machine's feet, and set the tool box aside.
  5. Remove the four screws securing the machine stand to the pallet with a 19 mm socket wrench.
  6. To install the machine stand's feet, you must first lay it on its front surface. Put a large piece of cardboard (or similar) on the floor to protect the machine stand.
  1. Lift the machine stand off of the pallet, and put it on the cardboard.
  2. Open the accessory box that you set aside in Step 9, and identify the four legs.
  3. Thread one leg into each corner of the machine stand.
NOTE: You can insert a screwdriver into the holes on the side of the legs to tighten them.
  1. Find the four feet that you set aside in Step 10.
  2. Thread one foot into each leg, making sure that the leg and foot assembly is 8-1/4 in. tall.
Figure 1: Installing the legs and feet onto the machine stand.
  1. Lift the machine stand off of the floor, and set it down onto its feet.
This is a section of the 8L operator's manual. To view the whole manual, go to Tormach document UM10753.
