8L Knowledge Base
Unpack the Machine Crate
Tools and Items Required
  • 19 mm socket wrench
  • Phillips screwdriver
  • Snips
  • Wood blocks
  • Work gloves
  3. Remove the screws from the bottom of the crate with a Phillips screwdriver.
  1. Before you lift the top of the shipping crate off of the pallet, verify that you have assistance to help you. We recommend lifting it with at least two people.
  2. Remove the top of the shipping crate and set it aside.
  3. Remove and discard the plastic wrap from the machine.
  4. Inspect the item(s):
  1. Identify the toolbox inside the machine's enclosure. Set the toolbox aside for now — it includes the machine's four leveling feet, which you'll need later in the installation procedure.
Figure 1: Toolbox inside the machine's enclosure.
Remove the four bolts from the bottom of the pallet with a 19 mm socket wrench. Discard the bolts.
This is a section of the 8L operator's manual. To view the whole manual, go to Tormach document UM10753.
