8L Knowledge Base
Before You Begin and Move the Pallet
Inspect the item(s):
  • Note any damage on the delivery receipt before signing for the shipment. If there is extensive visible damage to the machine, refuse to accept the shipment.
If there are any items that have not yet been delivered, we recommend waiting until you've received all shipments to begin installing the machine. Depending on the product and options ordered, the system may arrive in one or more shipments of:
  • Accessories (if applicable)
  • Machine
NOTE: The machine system and large accessories are sent by freight carrier. Smaller accessories may be sent by parcel service.
Installation Tools and Items
Before uncrating and installing your machine, collect the following tools and items.
  • 19 mm socket wrench
  • Cardboard piece, large
  • Carpenter's level
  • 500-lb capacity engine hoist
  • Lifting straps
  • Metric hex wrench set
  • Pallet jack
  • Phillips screwdriver
  • Snips
  • Wood blocks
  • Work gloves
Move the Pallet
Shipments arrive in crates loaded on pallets, which the freight carrier unloads onto the curb or loading dock.
Verify that the ground surface is smooth and clean of debris, and then use a pallet jack to move the pallet(s) to the desired installation location.
This is a section of the 8L operator's manual. To view the whole manual, go to Tormach document UM10753.
