8L Knowledge Base
X-Axis
10" (254 mm)
Z-Axis
10" (254 mm)
Spindle Speed
Low 180 rpm to 2500 rpm
High 350 rpm to 5000 rpm
Through Spindle Bore
1" (25 mm)
Maximum Workpiece Length
10" (254 mm) with tailstock
Maximum Feed Rate
X- and Z-Axis
150 IPM (3.8 m/min)
Tailstock
Taper
MT2
Diameter
0.9" (22 mm)
Travel
2.2" (55 mm)
Table Length
7.5" (191 mm)
Table Width
4" (102 mm)
Maximum Swing Over Bed
8" (200 mm)
Maximum Swing Over Carriage
4" (100 mm)
Machine Footprint
42" × 36" (1.1 m × 0.9 m)
Overall System Height
52" (1.8 m)
Typical System Weight
600 lb (272 kg)
Coolant Tank Capacity
6 gal (23 liters)
Primary Power Required
Single-Phase 115 Vac, 50/60 Hz
Recommended Circuit Amperage
Dedicated 15 A breaker
This is a section of the 8L operator's manual. To view the whole manual, go to Tormach document UM10753.
