1300PL Knowledge Base
1300PL Machine Maintenance
Maintenance Safety
All Maintenance Procedures
  • Power off the machine and disconnect the pneumatic supply before doing any maintenance procedures.
  • When appropriate, lockout/tagout the and the pneumatic supply line before doing any maintenance procedures.
Swarf Maintenance Procedures
Wear work gloves.
Maintenance Schedules
If you disassemble any components, refer to the machine's reference drawings when you've completed the maintenance procedure. For information, see Diagrams and Parts Lists. For any additional support, we can help. Create a support ticket with Tormach Technical Support at tormach.com/how-to-submit-a-support-ticket for guidance on how to proceed.
Daily
  • Clean the machine of any dust or abrasive particle buildup with a vacuum and brushes.
  • Wipe dust off of the linear rails with a clean cloth.
Weekly
  • Examine the water table's level and, if necessary, add water / rust inhibitor.
  • Check your plasma torch consumables for wear and replace if needed.
Monthly
  • Clean the electrical cabinet vents of dust with a clean cloth or compressed air.
  • Remove the slats and clean sediment buildup from the bottom of the water table.
Semi-Annually
  • Check drive belts for wear and re-tension if needed.
  • Remove faceplate from torch lifter and clean lead screw with a lint-free cloth.
As Needed
Replace the water table's slats when they have been worn away too much to hold stock securely.
Adjust Belt Tension
This is a section of the 1300PL operator's manual. To view the whole manual, go to Tormach document UM10720.
