1300PL Knowledge Base
Performance Expectations
Cutting Performance Reference
This machine is capable of cutting any metal that can be cut with a plasma torch at or near the recommended feeds and speeds. Verify that the programmed cuts do not exceed the maximum feed rate in X and Y.
  • Maximum Feed Rate 1000 IPM (25.4 m/min)
Torch Height Control Reference
Success using torch height control depends largely on the voltage setting selected at run time, and its relation to cutting feed rate. Make sure that your material is flat enough that vertical movement of the torch would not exceed the maximum Z Torch Lifter feed rate.
  • Maximum Vertical Feed Rate 120 IPM (3.0 m/min)
Tip! For a cut programmed at 140 IPM where the material rises 1" vertically over a 10" cut, the required vertical feed rate would be (1/10) * 140 = 14 IPM.
Resolution and Accuracy Reference
Accuracy is heavily influenced by the techniques that the machinist uses. A skilled machinist can deliver accuracy that exceeds the specified accuracy from the manufacturer; an inexperienced machinist may have difficulty delivering the specified accuracy. We can't predict operator accuracy, but the specified accuracy is an important reference point.
The accuracy and overall quality of plasma-cut parts depends on plasma torch settings, air supply quality, workpiece material properties, toolpath parameters, and other dynamic factors. As such, the following accuracy specifications are for the machine's motion control system only.
  • Resolution 0.0005" (.0127 mm)
NOTE: The resolution of motion is the minimum discrete positional move.
  • Repeatability ±0.001" (±0.0254 mm)
  • Positional Accuracy ≤0.005 in./ft (130 micron / 300 mm)
NOTE: Positional accuracy takes into account items like backlash in the drive system and total composite error of the gear rack.
X-Axis
48.5" (1232 mm)
Y-Axis
50" (1270 mm)
Z-Axis
3.9" (100 mm)
Maximum Feed Rate
X- and Y-Axis
Z-Axis
120 IPM (3.0 m/min)
Primary Power Required
Single-Phase 230 Vac, 50/60 Hz
Recommended Circuit Amperage
Dedicated 15 A breaker
Table Specifications
Table Size
51.2" x 51.2" (1300 mm x 1300 mm)
Table Type
Water Table
Weight Capacity (Excluding Water)
750 lb (340 kg)
Water Capacity
59 US gallons (223 liters)
Gantry Clearance
7.0" (177 mm)
Machine Footprint
78" × 70" (1.95 m x 1.7 m)
Overall System Height
55" (1.4 m)
Typical System Weight
1232 lb (559 kg)
Linear Motion Components
X and Y Axis Motor
Servo Driven
Z Axis Motor
NEMA 23 Stepper
Guideways
Precision Linear Guideway
Power Transmission
Planetary Gear (X Axis)
5mm HTD Belt (Y Axis)
Machine Construction
Water Table
Welded Steel
Machine Base
Welded Steel
Gantry Bridge
Aluminum
Gantry Supports
Steel
Controller
Control System
PathPilot (v2.4.x or newer)
Resolution
0.0005" (.0127 mm)
Repeatability
Positional Accuracy
This is a section of the 1300PL operator's manual. To view the whole manual, go to Tormach document UM10720.
