24R Knowledge Base
Performance Expectations
Cutting Performance
This machine is capable of cutting a wide variety of materials (for information, see Intended Use) at or near their recommended feeds and speeds. Make sure that your workpiece is held as rigidly as possible and use the most rigid tooling available for roughing cuts. Verify that the programmed operations do not exceed the available spindle power.
  • Spindle Speed Range 10,000 rpm to 24,000 rpm
  • Spindle Power Rating 2 hp (1.5 kW)
  • Maximum Feed Rate 200 IPM (5.0 m/min)
Resolution and Accuracy
Accuracy is heavily influenced by the techniques that the machinist uses. A skilled machinist can deliver accuracy that exceeds the specified accuracy from the manufacturer; an inexperienced machinist may have difficulty delivering the specified accuracy. We can't predict operator accuracy, but the specified accuracy is an important reference point.
  • Resolution 0.00025" (0.006 mm)
NOTE: The resolution of motion is the minimum discrete positional move.
  • Ball Screw Positional Accuracy ±0.002 in./ft (±50 micron/300 mm)
  • Repeatability ±0.001" (±0.0254 mm)
X-Axis
24.75" (628 mm)
Y-Axis
55.75" (1416 mm)
Z-Axis
6.7" (170 mm)
Spindle Power
2 hp (1.5 kW)
Spindle Type
Electrospindle With Reverse
Minimum Speed
10,000 rpm
Maximum Speed
24,000 rpm
Cooling
Liquid
Spindle Taper
ER20
Thread Machining
Thread Mill
Maximum Feed Rate
X-, Y-, and Z-Axis
200 IPM (5.0 m/min)
Primary Power Required
Single-Phase 115 Vac, 50/60 Hz
Recommended Circuit Amperage
Dedicated 15 A breaker
Table Size
26.7" × 65" (680 mm × 1651 mm)
Table Type
Integrated Vacuum Table
Gantry Clearance
6" (154 mm)
Machine Footprint
71" × 39" (1.8 m × 1 m)
Overall System Height
77" (1.9 m)
Typical System Weight
900 lb (408 kg)
Linear Motion Components
Axis Motor
Stepper Driven
Guideways
Precision Linear Guideway
Ball Screw Diameter
16 mm
Machine Construction
Stand
Welded Steel
Machine Base
Cast Iron
Gantry Bridge
Aluminum
Gantry Supports
Aluminum
Controller
Control System
PathPilot (v2.4.x or newer)
Resolution
0.00025" (0.006 mm)
Repeatability
