15L Knowledge Base
Mechanical
X-axis
10”
Z-axis
12”
Feed Rates
Rapid Speeds
60 IPM
Key Dimensions
Table Length
26”
Table Width
6”
Tool Holding
Gang tooling plate with three T-slots 0.625” (5/8”) Center Slot: 0.00 + 0.004” – Outer Slots: 0.000 + 0.008”
Manual quick change tool post.
8-position turret
Swing Over Bed
15”
Swing Over Carriage
6.2” (turret or manual tool post); 1.88” (gang plate)
Footprint
55” W x 66” H x 29” D
Speed Range
250 to 3500 RPM (5C), 180 to 2500 RPM (6”chuck)
Horsepower
3 hp continuous
Drive System
Cartridge style spindle with double V-belt transmission
Design
D1-4 spindle w/ removable 5C taper insert
Temperature
Operating Range
55°F-100°F (13°C-38°C)
Electrical
Power Requirements
Primary (machine tool)
200 to 250 VAC1 single phase
Secondary (control/coolant systems)
115 VAC single phase
Recommended Circuit Amperage2
Primary
20 AMP
Secondary
15 AMP (GFI protected)
1 230 VAC recommended; For voltages under 230 VAC, use of a Buck-Boost Transformer (PN 32554) is recommended.
2 Dedicated circuits recommended; do not use ground-fault interrupter (GFI) with primary circuit.
This is a section of the 15L operator's manual. To view the whole manual, go to Tormach document UM10225.
