15L Knowledge Base
15L Maintenance
Lathe Maintenance Schedule
Frequency
Completed
Item
Daily
Check coolant level (12 gallon capacity)
Check oiler level and top off as needed (Auto Oiler 2.1 quarts / Manual Oiler 0.25 quart)
Clean chips from ways and carriage
Spray exposed, non-painted metal surfaces areas with WD-40® or similar to prevent rust
Weekly
Check/adjust draw tube tension on 5C lever closer (if applicable)
Clean chip basket on coolant tank
Check air gauge/regulator for proper PSI (90 PSI minimum)
Use mild cleaner to clean all exterior surfaces (no solvents)
Check oil and grease reservoirs; top up as needed
Monthly
Dispose of oil in drain bucket
Remove coolant tank pump and clean out sediment buildup in tank; reinstall
Inspect electrical cabinet vent(s) for dust build up; if necessary, wipe vents with clean cloth or use compressed air to remove dust if accumulation is excessive
Every Six Months
Inspect way covers as needed to ensure proper operation; replace as needed
Inspect oil system for blockages; clean/replace as needed
Check lubrication hoses for signs of wear or cracking; replace as needed
Every 12 Months
Check limit switches for proper function; replace as needed
Check door switches for proper function; replace as needed
This is a section of the 15L operator's manual. To view the whole manual, go to Tormach document UM10225.
If you have additional questions, we can help. Create a support ticket with Tormach Technical Support at http://tormach.com/how-to-submit-a-support-ticket for guidance on how to proceed.
