PCNC 1100 Knowledge Base
Open a Support Ticket
Forums
Tormach YouTube
Tech Support YouTube
Tormach.com
Main navigation
Close navigation
Main
Forums
Tormach YouTube
Tormach.com
Main
About Your Machine
Safety
Site Planning and Prep
Unpack and Mount the Machine
Install PathPilot Controller
Essential Controls Overview
Power Off/Power On Procedure
Validate Basic Installation
Controller Customization
Accessory Installation
Deluxe Stand - PCNC 1100
Power Drawbar - PCNC 1100
ATC
10 Pocket Legacy ATC Installation Manual - PCNC 1100
12 Pocket M-Style ATC Installation Manual - PCNC 1100
Tool Change Scenarios
Enclosure - PCNC 1100
Enclosure Switch Kit - PCNC 1100
microARC 4
SmartCool
SmartCool Installation Manual
FogBuster
USB I/O
Touch Screen
Vise
Basic Steps to Square a Vise
ETS - Electronic Tool Setter
Automatic Oiler
RapidTurn
RapidTurn Installation
Power Drawbar Foot Pedal
6 and 8 in. 4th Axis
How to Setup a 4th Axis
Machine Maintenance
PCNC 1100 Maintenance
Machine Paint Color Codes
Flushing the Lubrication System
Accessory Maintenance
microARC 4 Maintenance
microARC Maintenance
Flood Coolant Maintenance
ATC Maintenance
Operation and Programming
Machine Operation
Basic Operation - PCNC 1100
Setting G30
Tormach Probing Routines
Probe & ETS Setup
Tweaking Your Work Offsets
PathPilot Settings Backup
Creeping Up on a Part
How to Cut Holes with CNC
PathPilot Programming
Programming - PCNC 1100
G28 Command
CAM Driven Probing
G64/M59 Guide
Macro Programming
Conversational Drill and Tap
Spindle Troubleshooting
Preventing Collet Slip
Changing Spindle Belt Range
Spindle Tram Adjustment
PCNC 1100 Spindle Rebuild
Chatter
ATC Troubleshooting
ATC Tab Disappears - Legacy ATC (10 Pocket)
Tray In Sensor Isn't Working - Legacy ATC (10 Pocket)
Tray is Moving Too Fast or Too Slow - Legacy ATC (10 Pocket)
Check Fuses and Cables Error
Device Homing Error
Tray-In Sensor Fault
Getting Out of an ATC Jam
Controller Troubleshooting
Controller Won't Power On - PCNC 1100
Motion System Troubleshooting
All Axes Won't Move When Commanded - PCNC 1100
One Axis Won't Move (or Only Moves in One Direction), and Other Axes Move - PCNC 1100
Can't Reference All Axes - PCNC 1100
Mill Gib/AC Bearing Adjustment and Backlash Compensation - PCNC 1100
Lost Motion Testing - PCNC 1100
Axis Movement is Noisy - PCNC 1100
Ballscrew Replacement
PCNC 1100 and 770 Series 1 and Series 2 Dip Switches
Machine Won't Power On - PCNC 1100
Accessory Troubleshooting
microARC 4 Troubleshooting
microARC 4 Repair
4th Axis Backlash Adjustment
RapidTurn Troubleshooting
Flood Coolant Troubleshooting
Electrical Schematics and Diagrams
Upper Mill Assembly - PCNC 1100
Connections - PCNC 1100
Stepper Connections - PCNC 1100
Operator Panel - PCNC 1100
Ribbon Cables - PCNC 1100
Lubrication System - PCNC 1100
Electrical Schematic - PCNC 1100
Home
On this Page
Troubleshooting Pages
