PCNC 1100 Knowledge Base
Mechanical
Key Dimensions (machine table)
Length
34” (86.4 cm)
Width
9.5” (24.1 cm)
T-Slot Width
5/8” (1.59 cm)
T-Slot Center-to-Center Distance
2-3/8”
Number of Standard T-Slots
Three along X Axis
(Center slot precision ground to 0.625”)
Maximum Weight on Table
500 lbs. (227 kg)
Spindle Nose to Table (~max)
17” (43.2 cm)
Spindle Nose to Table (~min)
1” (2.5 cm)
Spindle Center to Column Face
11” (28 cm)
X Axis
18” (45.7 cm)
Y Axis
9.5” (24.1 cm)
Z Axis
16.5” (42 cm)
Speed Range
100-5140 RPM
Maximum Rating
1.5 hp; 2 hp peak
Drive System
Belt Driven (two positions)
Low Belt: 100-2000 RPM
High Belt: 250-5140 RPM
Taper
R8
Feed Rates
Rapids on X
110 IPM
Rapids on Y
110 IPM
Rapids on Z
90 IPM
Max Cutting
110 IPM (X,Y), 90 IPM (Z)
Temperature
Operating Range
45°F-100°F (7°C-38°C)
Electrical
Power Requirements
Primary
200 to 250 VAC single phase, 50/60 Hz
Secondary (control and coolant systems)
115 VAC single phase, 50/60 Hz
Recommended Circuit Amperage
Primary
20 AMP
Secondary
15 AMP (GFI protected)
Note: 230 VAC recommended; For voltages under 230 VAC, use of a Buck-Boost Transformer (PN 32554) is recommended.
Dedicated circuits recommended; do not use ground-fault interrupter (GFI) with primary circuit.
This is a section of the PCNC 1100 operator's manual. To view the whole manual, go to Tormach document UM10349.
