770M Knowledge Base
Backsplash and Splash Guard
IMPORTANT! If you're installing an enclosure, don't install the backsplash or splash guard; you don't need them if you have an enclosure. Go to “Install the Enclosure”.
  1. Attach the backsplash to the left-hand chip pan with a 4 mm hex wrench and two M6 × 1.0 - 12 screws.
Figure 1: Backsplash aligned with the left-hand chip pan.
  1. Attach the backsplash to the rear of the left-hand chip pan with a 4 mm hex wrench and three M6 × 1.0 - 12 screws.
Figure 2: Backsplash aligned with the rear of the left-hand chip pan.
  1. Connect the two backsplash panels together with a 4 mm hex wrench and three M6 × 1.0 - 12 screws.
Figure 3: Connecting the two backsplash panels together.
  1. Attach the sides of the splash guard to the splash guard connecting plate with two M5 × 20 mm screws.
  2. Move the plastic splash guard between the two sides of the splash guard.
  3. Remove the four set screws from the four corners of the machine table, and then discard the set screws.
  4. Attach the splash guard assembly to the four corners on the machine table with the four provided socket head cap screws.
