Assemble the Machine Stand
Tools and Items Required
  • Work gloves
  • Hammer
  • Pry bar
  • Snips
  4. Inspect the item(s):
    1. Photograph any damage that may have occurred during shipping.
    2. Verify the received goods against the packing list.
  5. Find the accessory box inside the Machine Stand, which contains the feet for the Machine Stand. Set it aside for later installation.
  6. Remove the shipping bolts on the coolant tank, and then move it out of the Machine Stand and off of the pallet.
  7. In the coolant tank, find four casters and their hardware.
  8. Attach each of the four casters to the bottom of the coolant tank with four M6 × 12 mm socket head cap screws, spring washers, and flat washers. Then, set the coolant tank aside for later installation.
  9. Remove the four nuts securing the Machine Stand to the pallet with a 17 mm wrench. Discard the four nuts.
  10. To install the Machine Stand's feet, you must first lay it on its front surface. Put a large piece of cardboard (or similar) on the floor to protect the Machine Stand.
  11. Lift the Machine Stand off the pallet, and set it down on the cardboard that you put on the floor in Step 10.
Figure 1: Cardboard on the floor to set the Machine Stand on.
  1. Open the accessory box that you set aside in Step 5, and then identify the hardware inside (which is used to assemble the feet for the Machine Stand).
    NOTE: There are four large spacers in the accessory box that are used to assemble the feet for a 770M/MX mill. If you're assembling the feet for an 1100M/MX mill, discard the spacers.
  2. Identify the foot pad from the accessory box, and unscrew the foot adjuster as shown in the following image. Then, apply Anti-Seize to both components, and reassemble the foot pad.
Figure 2: Disassembling the foot pad to apply Anti-Seize on each component.
  1. Put the foot adjuster back into the base of the foot pad, but don't tighten it completely. Leave two threads visible so that you can adjust the stand up or down later in this procedure.
  2. Put the threaded end of one M12 stud into each foot pad.
Figure 3: Machine Stand foot assembly.
  1. Put one spacer on the M12 stud in each foot pad.
  2. Put one foot assembly into the corner of the Machine Stand, and then use one M12 washer and one M12 nut to secure the foot assembly in place by hand.
Figure 4: One foot assembly aligned with the corner of the Machine Stand.
NOTE: Only attach the feet so that they're finger-tight. You'll tighten them completely after you've leveled the stand.
Repeat this step for the remaining three foot assemblies.
  1. Tilt the Machine Stand off the floor and onto its feet.
Figure 5: The Machine Stand moved onto its newly installed feet.
  1. Level the feet as needed with the provided 3/8 in. (or 10 mm) adjustment bar.
  2. Securely tighten all four of the feet to the Machine Stand with a 19 mm wrench.
