Open a Support Ticket
Forums
Tormach YouTube
Tech Support YouTube
Tormach.com
Main navigation
Close navigation
Main
Forums
Tormach YouTube
Tormach.com
Main
About Your Machine
Safety
770M/MX Torque Curves (MX - MF/MH Serials)
Site Requirements
Assemble the Machine Stand
Unpack and Mount the Machine
PathPilot Controller
Manual Oiler
Verify the Installation
Chip Pans
Enclosure
Accessory Installation
ATC
ATC Installation Manual - 770MX
Tool Change Scenarios
microARC 4
6 and 8 in. 4th Axis
4th Axis Installation Manual
How to Setup a 4th Axis
RapidTurn
RapidTurn Installation
Operator Console
Operator Console Installation Video - 770MX
SmartCool
SmartCool Installation Manual
Fogbuster
USB I/O
Flood Coolant
Flood Coolant Kit
Automatic Oiler
Touch Screen
Vise
Basic Steps to Square a Vise
ETS - Electronic Tool Setter
Power Drawbar Foot Pedal
Machine Maintenance
770MX Maintenance
Machine Paint Color Codes
Accessory Maintenance
ATC Maintenance
microARC 4 Maintenance
microARC Maintenance
Flood Coolant Maintenance
Operation and Programming
Machine Operation
System Basics - 770MX
PathPilot Interface Overview - 770MX
PathPilot Tools and Features - 770MX
Basic Operations - 770MX
PathPilot Settings Backup
Creeping Up on a Part
How to Cut Holes with CNC
Setting G30
Tormach Probing Routines
Tweaking Your Work Offsets
Probe & ETS Setup
PathPilot Programming
Programming - 770MX
G28 Command
CAM Driven Probing
G64/M59 Guide
Macro Programming
Conversational Drill and Tap
Spindle Troubleshooting
Spindle Tram Adjustment
Changing Spindle Belt Range
Spindle Won't Turn
Spindle Orient or at Speed Fails
Chatter
ATC Troubleshooting
Device Homing Error
Tray-In Sensor Fault
Manual Tool Change with Dead ATC Board - 770MX
Check Fuses and Cabling Error
Getting Out of an ATC Jam
Controller Won't Power On - 770MX
No Ethernet Link Detected Troubleshooting - 770MX
Motion System Troubleshooting
Mill Gib/AC Bearing Adjustment and Backlash Compensation - 770MX
Ballscrew Replacement
Lost Motion Testing - 770MX
All Axes Won't Move When Commanded - 770MX
One Axis Won't Move (or Only Moves in One Direction), and Other Axes Move - 770MX
Axis Movement is Noisy - 770MX
Machine Won't Power On - 770MX
Accessory Troubleshooting
microARC 4 Troubleshooting
microARC 4 Repair
4th Axis Backlash Adjustment
RapidTurn Troubleshooting
Flood Coolant Troubleshooting
Coolant Pump Won't Run
Diagrams and Parts List
Base Machine - 770MX
Spindle Cartridge - 770MX
Spindle Head - 770MX
BT30 Power Drawbar Cylinder - 770MX
Power Drawbar Push Button - 770MX
Spindle Motor Cover - 770MX
X-Axis Assembly - 770MX
Y-Axis Assembly - 770MX
Y-Axis Saddle - 770MX
X-Y Axis Assembly - 770MX
Lubrication/Oil System - 770MX
115 VAC Power - 770MX
24 VDC Controls - 770MX
Axis Drive Bus - 770MX
Spindle Drive - 770MX
Machine Control Board - 770MX
Limit/Door Switches - 770MX
Grounds - 770MX
Operator Box Layout - 770MX
Wiring Table - 770MX
Home
770MX (MF/MH) Knowledge Base
On this Page
Sections
microARC 4 Repair
