1500MX Knowledge Base
X-Axis
19.7" (500 mm)
Y-Axis
13.8" (350 mm)
Z-Axis
14" (356 mm)
Spindle-to-Table Maximum Clearance
17.7" (450 mm)
Spindle-to-Table Minimum Clearance
3.7" (96 mm)
Spindle Centerline to Machine Column
14.7" (370 mm)
Spindle Power (Continuous)
4 hp (3 kW)
Spindle Power (4-Minute Overload)
6 hp (4.5 kW)
Spindle Maximum Speed
10,000 rpm
Transmission
5M Toothed Belt
Spindle Taper
BT30
Thread Machining
Rigid Tapping, Tension/Compression, Thread Mill
Maximum Feed Rate
X- and Y-Axis
1200 IPM (30.5 m/min)
Z-Axis
600 IPM (15.2 m/min)
Axis Motor
Servo Driven
Power and Air
Primary Power Required*
Single-Phase 230 Vac, 50/60 Hz
Recommended Circuit Amperage*
30 A breaker
Plug Type
NEMA L6-30P
Air Required
90-120 psi
Table
Table Size
35" × 12.75" (890 mm × 325 mm)
T-Slot Size
5/8" (15.9 mm) (three slots)
T-Slot Spacing
3.9" (100 mm)
Maximum Weight on Table
300 lb (136 kg)
Overall Dimensions
Machine Size†
86" × 104" (2.2 m × 2.6 m)
Overall System Height†
94" (2.4 m)
Typical System Weight†
2800 lb (1270 kg)
*Additional outlets may be required for optional accessories.
†Installed size and weight depend on machine options and accessories. You may need additional space for service or maintenance access. Refer to Site Requirements for additional guidance.
