1500MX Knowledge Base
Groups of Inputs and Outputs Aren't Functioning - 1500MX
Check Wiring Between Drive and Breakout Board
Reason: Loose IO cable between servo drive and servo IO breakout board.
  • Each servo drive is responsible for a group of dedicated inputs and outputs.
  • Use the “Servo Drive Inputs and Outputs” table to identify which drive is responsible for the non-functional inputs and outputs.
  • Check the identified IO cable and its connections at the Servo IO Breakout Board and Servo Drive.
Identifier
Servo Drive
IO Cable Identifier
Inputs
Outputs
DR1
IO-1
Spindle Index Pulse
Power Drawbar
Power Drawbar LED
Spindle Drive Contactor Start Pulse
DR2
X-Axis
IO-4
Accessory Input 1
Accessory Input 2
TSC Input 1
TSC Input 2
Flood Coolant
Washdown Coolant
Accessory Output 1
DR3
Y-Axis
IO-5
Probe Trigger
Probe Pulse
Probe Battery
Probe Error
Probe Activation
Tool Setter Activation
MQL (Mist)
DR4
Z-Axis
IO-6
Enclosure Lock
Power Drawbar Button
Enclosure Door Lock
TSC Power
Z-Axis Brake
DR5
A-Axis
IO-9
