Maintenance Safety
All Maintenance Procedures
Understand that the machine is automatically controlled and can start at any time.
Wear safety eye protection rated for ANSI Z87+.
Swarf Maintenance Procedures
Wear work gloves.
Coolant Maintenance Procedures
Wear rubber gloves.
Maintenance Schedules
NOTE: Before you begin any maintenance procedures, read and understand " Maintenance Safety".
If you disassemble any components, refer to the machine's reference drawings when you've completed the maintenance procedure. For any additional support, we can help. Create a support ticket with Tormach Technical Support at tormach.com/how-to-submit-a-support-ticket for guidance on how to proceed.
Daily
Clean the blade brush of swarf.
Clean the drip pan of swarf.
Examine the drip pan grate for clogs.
Examine the coolant level and condition.
Use a rust inhibitor on all exposed, non-lubricated, non-painted metal surfaces.
NOTE: Don't use rust inhibitor on the guide rails or vice lead screw.
Verify that the FRL Filter-Regulator-Lubricator has at least 90 psi compressed air, and that the lubricator has air tool oil above the bottom of the plastic tube.
Apply oil (like E-900 ball screw lubricant, or similar) to the linear rails.
Weekly
Clean all exterior surfaces with a clean rag.
Examine the blade brush and adjust it if it's not in contact with the blade.
Monthly
Clean the electrical cabinet of dust with a clean cloth or compressed air.
Put #2 tube grease on each guide rail within the travel path of the infeed table.
Clean fine swarf from the coolant tank.
Semi-Annually
NOTE: After the first 90 days of operation, complete the items on this list. After that, complete the items every six months.
Examine the motor belt for wear.
Lightly lubricate the vise lead screw with #2 tube grease.
Annually
Inspect the gearbox for leaks.
Replace the Gearbox Oil
Power off the bandsaw and disconnect it from the main air supply.
Push the Emergency Stop button on the operator panel to lock it into the disabled position.
Turn the Main Disconnect switch to OFF.
Mains power is disconnected from the machine. -
Disconnect the air line from your site from the input port on the FRL Filter-Regulator-Lubricator.
Put a catch pan for the gear oil below the gearbox drain plug.
Remove the four bolts from the gear box, and set aside the cover plate and gasket.
Remove the drain plug and allow the oil to drain out.
Remove the remaining oil with a rag.
Install the drain plug and fill the gearbox with approximately 10 oz (0.3 liters) of SAE 90 Gear Oil (ISO 220).
Replace the cover plate and gasket, and secure them in place with the bolts that you set aside in Step 3.
This is a section of the AF50 Autofeed Bandsaw operator's manual. To view the whole manual, go to Tormach document UM10538.
