Programmable Automatic Workpiece Positioning |
Cut Lengths |
0.157 in. to 50 in. (4 mm to 1270 mm) |
Maximum Length Per Stroke |
Up to 10 in. (254 mm) |
Maximum Strokes per Part |
5 |
Maximum Parts per Program |
999 |
Maximum Capacity |
Rectangular Stock |
6 in. tall × 8 in. wide (152 mm tall × 203 mm wide) |
Round Stock |
7 in. (178 mm) diameter |
Material Weight |
250 lbs (113 kg), subject to air supply pressure |
Blade |
Motor Power |
1 hp (0.75 kW) |
Blade Speeds |
60 Hz: 90, 134, 195, 255 ft/min (27, 41, 59, 78 m/min) 50 Hz: 70, 110, 160, 210 ft/min (22, 34, 49, 64 m/min) |
Blade Length |
93 in. (2362 mm) |
Blade Width |
0.75 in. (19 mm) |
Blade Thickness |
0.035 in. (0.9 mm) |
Coolant |
Capacity |
2.65 gal (10 L) |
Dimensions |
Floor-To-Table Height |
22 in. (559 mm) |
Typical System Weight |
450 lb (205 kg) |
Power and Air Requirements |
Primary Power |
Single-Phase 115 Vac, 50/60 Hz |
Required Circuit Amperage |
Dedicated 15 A breaker |
Compressed Air Source |
90 psi to 120 psi (620 kPa to 827 kPa) |
Space Requirements |
Minimum Depth |
36 in. (0.91 m) plus the length of stock |
Minimum Height |
67 in. (1.71 m) |
Minimum Width |
60 in. (1.53 m) |
This is a section of the AF50+ Autofeed Bandsaw operator's manual. To view the whole manual, go to Tormach document UM10825.
